Hello. Went out yesterday and went to start the car and click. Put a charger on the battery overnight and it said charged this morning, turn key, click. Put a meter on battery 13v. Put load test on battery good. check fuses look ok one was square couldn't tell. Moved it through the gears click. Tried to jump it from my van, click. Rocked it back and forth in park, click. No symptoms of any issues when I parked it to go on mini vaca on motorcycle 4 days previously. Any suggestions before I have it towed to garage? All dash and exterior lights etc work. Disconnected and reconnected battery cables also, no luck.
2006 G6, 4 cyl 78,000 miles
Thanks
2007 gt retractable
did you clean the battery cables when you had them off?or the starter may have gone bad.if the solenoid is on the starter tap it with a hammer.
