Not sure what radio you have but should just have to push CLOCK button and then the display will flash the HOURS digit and will say ADJ HOURS. You rotate the DISP knob clockwise to increment and counterclockwise to decrement. When you finish then push the CLOCK button again to adjust Minutes in a similar manner. After that is done you can either push CLOCK one more time to Exit the clock set mode or let it time out.
Thanks
Thanks for your quick reply. I have the 6 disc premium audio system. I think that it should be basically the same as the other systems. I will attempt to change the tie when I go out next time.
Thanks again.
Medium Gray Malibu Maxx said:
Here's an easier way to set the clock...
Find an RDS station (like a low number NPR station, though just about any RDS station will do), wait a minute, then hold your clock button for a few seconds. It will automatically update to RDS time. :)
Depending on your area that may not work. I know none of the RDS stations around here support the time function.
I thought it is one of the easiest clocks to manually set time on since you have a knob to rotate and can travel in either direction so you don't have to worry about overshooting and having to go all the way around again.
