hello, i have a 2010 g6. i have replaced my control arm and ball joints, inner and outer tie rod ends, sway bar links, strut assembly’s and hub assembly. i am still getting a loud clunking sounding like it is coming from my passenger side, it’s whenever i go over bumps. i’m at a loss, i hope someone can help
08 convertible
Very few things left. I would look at the sway bar bushings, motor/trans mounts and possibly axle shafts. Does it always happen on bumps only? At any speed, accelerating, braking, turning?
I ended up figuring it out after asking the mechanic who did my trans flush to look at it. the guy who put on the control arms and tie rods and sway bar links, did not tighten the nut on the bottom so it was loose. replaced it with a new one because the old would not tighten, and the noise is gone now. thank you!
