Well, I will have all items here this week to start the build in the next few weeks. I have nothing left on my list to get, besides the fluids.
But, I could not pass this deal up. It's an DEI Co2 intercooler sprayer. This kits comes with it all and an extra bottle. I may look at a purge kit for it.
The CryO² Intercooler Sprayer mounts directly to the front of the intercooler or aftercooler and vents the liquid Co² directly onto the cooling fins, thus enhancing the performance of the intercooler by more than 50%. This component must always be the last in the CryO² system as it vents the liquid Co² charge
It will be hooked up. But, this is going to be mostly for show. But, can be used if I want to use it. I could not pass up the deal. Well worth over $600 dollars. It was cheap compared to that. Wanting something in the back seat area to take up some space. So, I figured this is what would look awesome installed back there and useable if needed.
Talked to DEI itself and they recommened to do this.
The CryO² Air Intake consists of an aerodynamically designed bulb with a cryogenic chamber which is mounted in a 4" segment of air tube. The air passes over the bulb, heat is removed from the air charge resulting in a colder, denser, more powerful charge. Dyno testing showed a reduction in intake air temperature of more than 50 degrees. The CryO² Air Intake can be used on turbocharged, supercharged or naturally aspirated applications. Multiple units can be used for colder results. Installs in minutes and comes with silicone connection sleeve, hose clamps and connection / vent hose.
