Over the past few years I have seen multiple posts regarding inability to open trunk. I've seen some horror stories with dealers replacing incorrect parts etc. I recently came upon a TSB for this issue, and believe it should be posted here. Is this allowed?
Thanks,
Eric
Thanks I already had it loaded on my AWS site to do just what you did only wasn't sure if I should.
Thank You,
Eric
There is one more issue a broken wire to the sensor switch can cause that is not so noticeable. Apparently the safety routines in the BCM also disables the rear window defroster when it disables the trunk release. I'd had this issue for years. I had a battery quick disconnect in place so I could use my trunk. After fixing this a couple weeks ago I just noticed my rear window defroster suddenly started working again.
