Noticed today that the G6 is leaking coolant. I checked all of the hoses and the radiator and did not find anything. I am guessing that it is the water pump. Anyone else had the same problem? Anything else to check?
the first time i was leaking coolant it was the crossover pipe gasket. That was about 3-4 mths ago. Last week I was leaking coolant again and the weaterpump had to be replaced. So far so good. Hope this helps.
Dealer just called and it was in fact a bad water pump. And all of it was covered under the 5/100.
yep bad water pump my g6 was leaking last friday
i read blue jackets post and took mine to the dealer covered under 5/100
mine was also leaking from recovery tank i guess loss of pressure makes the tank piss from the hole on the underside.
Varsity Squad
I didnt have a coolant leak, but I know someone else's GTP had a leak at the lower intake gasket, it too was under warranty. Something else to keep an eye out for.
