So does anyone have a pic of where the coolant temp sensor is at on this motor. Can't seem to locate it. From other diagrams I seen I thought it was in the location pictured but I don't see it there either..
The code was p0128The sensor should be on the end of the forward cyl. head, basically under the throttle body and heater core pipes are in the way. NOT often to see this sensor go bad, NORE COMMON is a bad thermostat. Why are you changing the sensor? Do you have specific code(s) for it and have FULLY diagnosed that it is not the T-stat or other problem?
P0128 code is most commonly found to be a stuck open T-stat, Comp. sees engine not getting to temp fast enough. Not an easier change than other motors, but definitely easier than the temp sensor that will probably not fix your problem. YES, a stuck open T-stat will turn on the rad fan(s) and do a couple other weird things. Mine went bad, and when I took it out there was a rubber ring around the main plate that shifted and stuck the stat partly open causing the P0128 code. Take the pass. headlight out for best access to the "stat" housing.The code was p0128
I just assumed it was that because I had another car that did the same thing where the radiator fans would stay on all the time when the cars on and it was that sensor. The temp gauge seems to work normally.
Okay thank you. I will do that first.P0128 code is most commonly found to be a stuck open T-stat, Comp. sees engine not getting to temp fast enough. Not an easier change than other motors, but definitely easier than the temp sensor that will probably not fix your problem. YES, a stuck open T-stat will turn on the rad fan(s) and do a couple other weird things. Mine went bad, and when I took it out there was a rubber ring around the main plate that shifted and stuck the stat partly open causing the P0128 code. Take the pass. headlight out for best access to the "stat" housing.
PLEASE report back what you find and how the "experience" went. If I remember right, I also took off the air tube from the air cleaner to throttle body for more "working room".Okay thank you. I will do that first.
Was the ECT sensor below this as suspected? I'm having to replace mine and I can't see it. Did you have to remove all this?I think this is it where the wire loom is going down but that black piece is right on top of it and I don't know how to remove it. What is that black part called?
Did you find it? I've been looking for 2 days now.Was the ECT sensor below this as suspected? I'm having to replace mine and I can't see it. Did you have to remove all this?
Yes I did. Scroll up to tmorales509 second post and the sensor is under that black unit. Remove the two hoses to get access to the sensor. You'll never see the sensor, only feel it.Did you find it? I've been looking for 2 days now.
