I have an '08 G6 that was involved in a small front end collision. There is a little body damage on the grill, but the radiator seems fine. The larger one of the cooling fans was bent and does not move (it appears it is only the plastic framework that was damaged and bent, the fan and motor seem to be in shape). The smaller fan moves freely when I do so with my hand before starting the engine. The engine heats up very quickly, but never goes above the normal operating temperature from before the accident. Is this something I can manually fix without replacing the fans, and do you think this is safe for the engine to be driving (there is no leaking of coolant or radiator damage).
