I should have taken pictures to help describe my problem, but here goes...the MAF is probably 1/4"-1/2" wider than the rubber "coupler" that was provided. I fought with it for about 10 minutes before I decided to cut it and "Jerry rig" it to fit. I ran some higher quality tape around the rubber coupler to close the gap and then installed the short pipe provided to attach the cone to. So basically the pipe is quite a bit smaller than the MAF.
So aparently the newer G6's need bigger connectors and a bigger cone. I'm going to measure and get a pipe with couplers to fit and then go with the cone that I have from AutoZone that is the right size...either way, I finally have CRABS...never thought I'd be excited to say it.
