Mobile Audio Specialist
http://www.andysautosport.com/ponti...ance/intakes/air_breathers/pilot_motorsports/
Would this work on the G6 3.5? I dont see why not. What do you think???
NO, and it might fudge with your evap/emissions system, In all honesty it's not need unless you have forced induction
Chrome Valve Cover Breather for your Engine. Screws into the front valve cover in place of the oil cap. Used to let air into the crank case on M90 equiped engines or to vent crank gases on engines with aftermarket power adders.
*PCM programming required on cars with drive by wire throttle bodies
Ok thanks
