this is a super simple mod guys and afterwards you'll love it.
i bought pilot automotive part number cz-184r because it can be plugged in or hardwired right now its plugged into the power outlet in the console.
first drill a small hole straight into the console in the rear of the cupholder straight into the console.
should come in like this
then i super glued small section at a time to the rim of the cupholder by holding it with a straw and bending it to the rim as i go. let it dry enough that the glue holds the wire in place as you go.
it should end up looking like this when you're done i left the rubber insert unglued so i could still clean it and it gives the rim a cool glow
then plug it in
