Hey guys. I just purchased an 07 G6 GTP. I'm having issues once you turn on the signal Light and turn, it doesn't wanna always turn off when you turn the wheel back. So I removed the cover on the steering column where the switch is located to investigate and found a purple wire cut coming from the headlight switch. I know this has nothing to do with the signal, but does anyone know what this wire is and why it's cut? Thanks!
I wonder if someone cut it so they couldn't turn off the daytime running lights... haha
Like what comes to mind is an over-protective parent getting a car for their kid... or over-protective spouse.
Your turn signal not cancelling is a problem I had. twice. They always just had to replace the turn signal switch and it was done under warranty. From what I could figure out it's actually pretty easy to replace.
GMPartsDirect has a new switch listed for under $30.
Could you give me a link to that switch please? Thanks for the quick response.
The problem with GMPartsDirect is I can't just give you a link to the part... But here's the site, You can just enter your car information and then in the search field just type "Turn Signal Switch" It should come right up.
This site has been the cheapest of all the GM Warehouse parts sites I could find.
GMPartsDirect
GMPartsDirect
Thank you so much. Bought one at the scrap yard. Installed it in about 5 min. Man that was easy. Works perfect!
Do you think that wire is cut so the the fog lights can turn on without the headlights on? I'm not sure how the headlights and fog lights behave together on the g6. If I start my car during the day and the switch is on auto the driving lights come on. If I push the fog lights switch, fogs and park lights come on and headlights turn off. When it gets dark the headlights turn on automatically. If I want just fogs and park lights on I turn the switch to park lights with the fog Light button pushed. Is this the way it works for all g6's?
