Pontiac G6 GT Coupe
Hello recently my g6 has been taking 5-10 seconds to shift into drive (1st) after moving the shifter into drive, it doesn't shift late with any other gears.
What could this be from?
I've recently checked and topped off my transmission fluid & i'm having it taken into ti get the recalled shifter cable replaced soon.
· Super Moderator
The shifter or fluid level would have been my initial guesses. Sounds like you have those covered. If the problem persists and you know someone with an advanced scan tool there may be transmission control module diagnostic codes that would give you more of a hint.
Pontiac G6 GT Coupe
Thanks I'll look into it!
Have lived with first gear hesitation issue for several years with my 07 GT. I would take it to the dealer and they did something with the computer but the fix was never permanent, like the cat always came back. Then I noticed it never happens when using the paddle shifter. Plus its more fun in any event.
