I have read a few posts about coolant vanishing and heat coming on and off etc. If this is u then you need a new thermostat. Your coolant is boiling out the overflow reservoir because it’s not making it to the radiator fast enough because the inner springs deteriorated over time. To change it remove passenger side headlight and it’s between the hoses . Remove them to access bolts. Good luck
