Inside the car the climate control fan speed is on 0 or off but are is still pumping out like if it was on 1 or 2. whats the problem and how do i fix it? thanking everyone in advance
is this happening even while the car isn't moving? While driving along, even if the fan is off the air from outside is getting pushed inside by the change in air pressure and such. And if you have it selected to blow on you and the vents are open you'll likely feel it.
But if its going on even when standing still, like the fan is clearly blowing when it's set to 0. Then it could be an issue with the climate control unit itself or possible the blower resistor, but I wouldn't think so...
RAM AIR!!
Mine does it when the car is moving and recirulate isn't selected. If you turn on recirulate and it is still doing it than you have problems.
