Take a flathead screwdriver and pop out the plastic covering from the straight side of the dome. Bend the smaller metal tabs of the larger tabs in so that the entire tab is straight so you can slide the bulb down the large tab. Do this with both sides. Most of it is observation and common sense. Don't bend the tabs too much or you could break them.
The bulb size is 561.
i just replaced my map reading lights on my 09 g6 , with red leds and i have a sunroof. all you need is a small flat head screw driver . to remove the lenses , you press and hold it like you are going to turn it on, then you use the flat head and pry GENTLY .at the gap that opens when you hold the button. then pull bulb and put new one back in watch the tabs
