I just bought a used 2007 G6 GTP. Unfortunately, the driver's side door looks like it's out of alignment. The window doesn't hit at exactly the same spot as the passenger side and the door doesn't sit quite flush. Not currently leaking, but it is noisier than I'd like. Anyone else have issues like this? Resolution?
The hinges probably need to be loosened so the door can be lifted then re-tighten, that often requires removing the fender to gain better access at the hinge bolts.
I'm assuming you have the two door, which has heavy doors, I wonder if replacement hinges are available...
It is the two door. This seems like a job for the pros, so I'll probably get them to fix it. I'd probably end up making a leak!
