Hey everyone, this is my first actual post and i hope someone can help me.
I have a 2007 G6 Sedan and it was recently hit in the Drivers Front Door. I have just odered a replacement door and should have it by the end of the week. I was wondering if anyone has channged out the door lock key cylinder and had a guide on how to do it. Im kind of hesitant on changing it out myself but before i take it anywhere to be done I figured to seek some help here.
welcome! if you open the door you'll see a black circle (about 1 inch diameter) at the end of the door...pop that off...use a torx bit (not sure the size) and unscrew the only screw you can see once that black circle is popped off. that will remove the entire handle..reinstall on the new door and you're in business.
where in NY are you...i'm in Syracuse
Thanks for the info revert, I'm smack dab in the middle of rochester and syracuse in waterloo. I have been thinking about getting a local meet together rather than the one in niagra falls, on.
Greenman i sent you my address, thanks.
