· 2006 Black G6 GT
If you are replacing you're speakers you dont need to buy anything additional....
They just fit into the stocks plastic mounting gear.
No need for those..
No need for those..
Actually, you have couple of choices if your replacing front speakers. Once the stock speaker are out, there are no pre-made holes for speakers. This is because the bracket comes off with the speaker. So either you make holes on the door to install the speakers or use another bracket to screw in the new speakers onto the bracket.
But those pics of that bracket seems like it would work because it has the same shape. But dont know abotu seize.
