I just cracked the Onstar antenna on my 08 GT while removing snow. Two things:
Does Anyone know where I can find a replacement?
How do I remove the antenna that is still on the roof? (the base of the module is still in place)
Thanks,
KDE
GMPartsDirect You can find it like this, Enter your car info. on the left go through these menus
-Electrical
-Body Electrical
-Antenna & Radio
-Antenna/Antenna Module, (Depending on convertible or not)
It's only like $18.00 But hopefully it's the correct part. I would think so.
As for removing the antenna. I would assume you would need to remove part of the headliner, Or some of the panels at the front on the ceiling. Pretty much get under that antenna.
I would guess there are a few screws that you simply remove and it all comes out.
I haven't removed one of those before, and I think it may have a hard wire coming from it that plugs into the stereo, so you might have to delve into that. But again, I can't be sure.
