Double din install info won't work
I will be installing a double din DVD player in the wife's car tomorrow and I have read that you will loose your keyless entry. But for the PAC adapter I got it did not say one thing about that. I realize the DIC info will be gone and some say to use a meta relocate. Wtf is that? You got any info on it?
Well I got the metra dash kit and the PAC C2R-GM11B harness adapter. I wired it all up but can't get any sound out of the speakers . I tested the output of the head unit & that does work. Makes me wonder if my adapter doesn't work or do I need a different one? It's all getting installed in a 2009 g6 with the dual nov radio. What other harness adapters have u guys used?
blue amp cable
Did you connect blue amp wire. I just finished an install for my suburban and I had same problem until I realized I missed the blue amp cable because of the built in BOSE system if you have monsoon then could be same problem?
