1 - 20 of 38 Posts
Hi, I am new here, My wife and I have a new 2006 G6 GT Sedan "Crimson Red' that we bought new in August, a week afer our purchase we noticed a creaking noise, seemingly from under the drvers side rocker panel or the "B" pillar area,(at first i thought it was the drivers seat bottom, but no... I tried lubing the weather seals around the front and back doors, to no avail, I went to the dealer for the 1st oil change around 1500 miles and mentioned it, they lubed the seals some more and called it "Body Flex". Got home and it still does it, when I turn onto my driveway apron from my street it makes a "ccccrrrrrreeeeeeaaaaakkkkkkkeeeee" sound. iit is a crunchy pecular noise.. I opened the drivers door while I pulled in and still heard it plain as day. Anyone encounter this nusiance? Has to be something under the rocker panel or behind the "B" pillar and I would call it more than the doors moving opposite of the body, the bolts are tight to the doors. any ideas? I cant live with the dealer discounting this noise as a new car with "Body Flex'. Thanks.....oh yea, the conventional sunroof shade panel was making some noise and they lubed it and it has vanished. now if they would address this creaking when going over and un-even surface.
I have not heard this, knock on wood!! I agree with taking it the dealership and taking them for a ride, but if your luck is like mine, last time my made a noise, we went for a ride and it didn't do it. I ended up at the dealership 4 or 5 times before they finally decided they heard the noise. I have noticed the excuse for every noise (on mine anyway) is that it's a new design/car, which is clearly unacceptable!!
I know what you are talking about...still havnt found a fix. Actually when I go over uneven areas (ie, entering a driveway, pulling off uneven pavement slowly) I can see my doors move slightly and shift. Ive always had a rattle and creak at slow speeds (the rattle is present at all times). Let me know if you manage to figure it out.
Anyone make SFCs for these things?
same thing.. my car flexes when going in to the driveway or up on the curb.. it's very annoying.. makes the car feel like a tin can.. and it cannot be safe.. the panomramic roof messes with the integrity of the body
Discussion Starter · #9 ·
Thanks for the replys, that is exactly it.....it sounds like the crinkling of an aluminum can. That is the sound. It does relate to "Body Flex"..I geuss? Something is flexing, I just find it hard to believe that it is the Rubber Door Seals against paint. I am off this weekend and intend to look under the cars rocker panel and behind the "B" pillar, if i can safely remove the interior trim without breaking anything.
Discussion Starter · #13 ·
It has rained all weeknd so I couldn't get under the car, but I did look like a "nut" (according to my wife) pulling into and back out of and over my driveway apron with both left doors open, it seems to me like it is a plastic(y) noise now that gets tighter as the car flexes with doors shut, I am thinking the bottom of one of the door panels (or both) is coming in contact with the interior panels and as the doors moves it pushes the two plastic pieces tighter together then releases as I crest the apron and stops when I get level again. kinda like (quiet) (creaaaaakkkeeee) (quiet). Only on drivers side. I did not see any scuffing on any of the panels where contact could be made. Will keep searching when I get a dry moment. And look closer for contact. I do not have the panoramic roof, I have the conventional rectangle sunroof.
Discussion Starter · #14 ·
Ahhhh, I checked for the noise and came to this conclusion, it is not the front or rear door making the noise,drivers seat or the rocker panel moulding. It creaks with both the doors wide open, that eliminates the doors moving, Will call dealer tommorow to schdule a check on it. Thanks
Discussion Starter · #16 ·
Thanks for the tip, I will check the fuel lines. I did find the rear seat shoulder belt teather bungee cord thing tucked between the corner side of the rear seat and the interior moulding. never would have known it had them until I felt around between the seat and the side of the car and pulled it out, and attatched it to seatbelt... I retrived the passenger side one too.. Thanks
Discussion Starter · #17 ·
I think I finally found the source of the creaking, it is the huge tin protection plate that covers the entire bottom of the plastic fuel tank. I pressed up on the front left corner of it and I heard the creak. Either it is rubbing the tank or the straps are creaking.That makes sense since the noise is under the drivers side of the rear seat. I called Dealer and made an appt. to have it checked and the Service Manager told me they are gathering info from a new service bulletin regarding a noise from the left side of G6's. and to call back Tuesday so he can let me know what that entails. May have to do with a suspension thing and not related to my huge tin gas tank sheild. It goes in next Friday. Thanks and I will keep you posted.
Discussion Starter · #18 ·
I took the G6 to the dealer, I drove with the Service Mgr and the creaking was there with the 2 doors open, we went back and they tightened every bolt in sight, they placed foam tape between the tank sheild and the tank, after about 45 minutes of waiting while they did this, He comes into the lounge and tells me that everything they did.......""did not do a thing"" for the creaking,it is still there... They want me to swap out cars with them this week so they can get into that "B" pillar and see what is making this annoying noise. At least I have someone on my side, as opposed to just being turned away, or getting the wonderful "Complaint not found" and sent on my way. So I am satisfied with the progress..... anyway,.,Wooo Hooo I get a Chevrolet Cobalt to drive for a few days!! How exciting....well, not really... I'll keep you posted.
Hi all, sorry to hear about the creaking...I did though notice another issue with the trunk on my 2005 G6GT. The bumper cover and the Trunk are soo close that the trunk is actually rubbing on the bumper cover and has scratched the whole thing. Small little scratches but I couldn't figure out for the longest time what the hell was causing it. Looks like there is enough room...but now that you all mention the Extra Special "Body Flex" that GM decided to build into the G6's...that might be why.
Good Luck!
Discussion Starter · #20 ·
I dropped off the G6 today,Monday 21 Nov. so it is there for a few days. Weird going from a G6 GT with the shiny chrome rims to an '06 Cobalt with crank up windows and manual side mirrors, oh well, I am grateful to get a free rental, and it only has 176 miles on it...will post the results in a few days.
1 - 20 of 38 Posts
