1 - 16 of 16 Posts
Is E85 really worth getting as far as price and gas mileage? With gas prices going up I've been considering it, but don't know anything about it so I don't know if it's a good option. Any input appreciated!
Whats the price difference?
IMO it wouldn't worth it unless E85 is at least 30-40% cheaper, which I doubt it is. The problems is that you are probably going to lose about 30% off your gas mileage because of the high ethanol content.
Can the G6 even run on E85?
Yeah I'm pretty sure it does. I know mines flexfuel. Not sure how much it cost though.
I too have a FlexFuel. About a month ago, I started using E85 and I cant tell a difference, except for price. Same power is there (that I can tell) as well as fuel economy. The price here is about a $.60+ difference.
Only the G6's with FlexFuel are made to run off of E85 I believe. If your vehicle doesnt call for it, then DONT USE IT!
I have not lost any gas mileage. Still fill up once a week. Same amount of power.
In winter, the ethanol base of the gas will increase due to the cold weather. (there is a date posted on the pump where I fill up)
G6Whitie
Yeah mine is flex fuel. I was under the impression that E85 is cheaper, but I'm not sure on that because we dont have any locally. I've been trying to decide if I want to try it, but if there's no difference then I think I'll wait.
The only difference I can tell is the price. E85 being cheaper. Now, saying that, E85 is perfectly fine to run in FlexFuel vehicles. (engine is made for it)
If you have an Android type phone, download the app called: KeenDriver (green leaf with a white gas pump picture)
You can find gas stations that sell E85 around you with that.
By the way, around me, E85 is about 30-40 cents cheaper.
G6Whitie
Discussion Starter #7 (Edited)
I tried looking for that app on my iPhone but it's not listed. I'm going to try looking it up online. .30-.40 is a pretty good difference I'll be trying it for sure if I can find it locally for a good price difference. The salesman told me you get about 5 miles less per gallon so I'm glad to see that isn't true. Now I know this may sound like a dumb question, but is it ok to mix it with regualr gas at first or should I run it as close to empty as possible before I switch to E85? Thanks :D
Edit: I found a station within 30 miles of my home. I called and the prices are 3.05 which is .44 cheaper so I'm going to go there.
Yes, its ok to mix. You can have 7/8 tank of regular unleaded and 1/8 tank of E85 or the total opposite of 7/8 E85 and 1/8 regular unleaded. (also all the variations between)
$.44 cheaper is a plus! You will be saving almost $1.00 per 2 gallons of gas! I would make your first fill-up when you are around that area......dont waste gas to get gas. Keep up the search as well, stations are picking up E85 all the time.
I ran regular unleaded for about the first 2 weeks having my car as I was searching for an E85 equipped station. After switching, I really havent been able to tell a difference at all.
Plus, its better for the environment! (lol)
G6Whitie
Now, I dont know alot but here is what I read on that first link and how I can compare to what I have experienced....
-and it burns cleaner than gas (how do emissions rise?)
-drivers have to make more frequent trips to the pump (i fill up once a week and drive my car literally everyday....same when I used regular unleaded)
-Is ethanol cheaper than gas? Surprise, surprise, it isn't. (this is false)
A computer system can probably nail down everything to a t and show me power loss and so on but as I said before, I cant tell a thing running E85.
G6Whitie
Onto the 2nd link.....
Discussion Starter #11
Ok so I finally got E85 today. I also got to use onstar directions for the first time so I was pretty happy about that. As far as anything else goes I can't say I'm so happy. I can smell it when I start my car, but I overfilled it so maybe that's why? My gas mileage has dropped from 23.7 to 16-17 mpg. I do notice a little more power or less hesistation. I don't think it's going to be worth the .29 cent difference. I'm glad I tried it once though.
Lifetime Member
If I write a review on a product I'm pushing then I hardly believe I'll give my product bad marks. Most (if not all) pros to E85 are from government run/funded organizations; E85 is a scam.
E85 is not cheaper to produce than gasoline, its not "better" for the environment and it does not produce less emissions w/o diminishing performance. These statistics that get shoved down our throats are lacking real data that matters; they play on the average Joes’ ignorance and unwillingness to research themselves.
Statistics are a fool’s proof. But hey, these are just my opinions from life experiences.:)
Leaving the E85 out of question, you were only getting 23.7 mpg with regular gas?
*Edit* I just asked my fiance about her mpg and she said she is getting 27-28 in town and 31-33 on the highway. She has an 07 GT. I guess alot depends on how you drive. I wont debate this issue. Just seemed a little low to me at first. *EDIT*
I just filled up tonight, a full tank from lower then "E". It cost me $42.50 at $3.28/gal. My "Fuel Range" says 369 miles. This week, or next, I will make sure to do some calculations and figure my mpg out. I run straight E85.
G6Whitie
You guys really need to do more research on this stuff.
Some are real close, yet still misconstruing info. If I had more time, I'd fill in the gaps-maybe Monday I will.
Discussion Starter #15
G6Whitie
Yeah I only get 23.7 that's based on what the DIC says. I've never seen anything over that, but would be nice if I ever do. I was told I would get about 3mpg less by getting a 6cyl. Compared to the 4, but I liked the GT. I've been trying to figure out how to get a little better mileage. With my 05 taurus I had up until Feb. Got 16-18mpg so I'm alot happier with 23.7 but when I had my 01 grandam I got 30-32.
OK...let me know if you have any questions after this. Numbers are from memory, so they are very close but could be a little off.
Stock car (AKA flexfuel):
-expect a loss of 10% in MPG
-expect a loss of 5% HP
The reason for the HP loss is the PCM is tuned "in the middle" but more towards regular fuel which the PCM assumes "bad gas" file (or whatever its called in the database) while using E85. Anyone using E85 on a vehicle not setup for flex should notice even worse side effects.
Modded-tuned properly:
-expect loss of 20% in mpg (if you modded/racing-do you really care???)
-expect an increase in HP of up to 10%
Now here's the tough part, you can't switch back and forth...PERIOD! Run to empty, change .bin file and fill with the other.
Most cars built after 1996 can run E85 with little to NO issues. Verifiy this by making sure you have plastic fuel lines. If you have metal lines-DO NOT EVER RUN ANY ALCOHOL DIRIVITIVE its will cause the metal to rot out. I also suggest running a "techron" fuel cleaner after running E85 unless you are flexfueled, as in very few cases the injectors will clog up after long term use.
The cost-wow...just call this a government kickback zone. Who looses money manufacturing E85? EVERYONE!!!! The corn growers get kickbacks, the manufacturer get kick backs (if they produce above the minimum)....transporters of E85 get kickbacks, gas stations get tax breaks....what else???? We still pay to much for it. Is there a cost effective way to do this? Not yet.
Think about it. 1 gallon of crude gets 5gal of reg gas, while 5 gal of corn get 1 gal of e85. How does that math work.
Now other than our tax dollars paying for this, there are nice gains for the performance world. I hope to be one of them Aug/Sept, my 700hp will be closer to 800hp, and interchangable (if I carry my netbook/HPT).
Have fun!
1 - 16 of 16 Posts
