1 - 1 of 1 Posts
Engine Control Module (ECM) X1 (LZ4 or LZE)
GM-1650395
Click to Enlarge
Connector Part Information
  • OEM: 13542537
  • Service: 15498847
  • Description: 73-Way F Receptacle 0.64 2.8 Sealed (BK)
Terminal Part Information
  • Pins: 73
  • Terminal/Tray: 7116-4152-02/9
  • Core/Insulation Crimp: 2/5
  • Release Tool/Test Probe: 12094430/J-35616-35 (VT)
  • Pins: 1, 9, 12, 13, 16, 17, 18, 19, 20, 23, 24, 27, 28, 29, 30, 31, 32, 33, 34, 36, 48, 50, 52, 56, 58, 59, 60, 61, 63, 64, 65, 68
  • Terminal/Tray: 33467-0003/23
  • Core/Insulation Crimp: H/H
  • Release Tool/Test Probe: J-38125-213/J-35616-64B (L-BU)
  • Pins: 10, 11, 47, 49, 69, 37, 38, 41
  • Terminal/Tray: 33467-0005/23
  • Core/Insulation Crimp: Pins 10, 11, 47, 49, 69 – K/K
  • Core/Insulation Crimp: Pins 37, 38, 41 – J/J
Pin​
Wire​
Circuit​
Function​
1​
0.35 OG/BK​
1786​
Park/Neutral Signal​
2–8​
Not Used​
9​
0.35 WH​
17​
Stop Lamp Control​
10​
0.8 PU​
3120​
HO2S High Signal – Bank 1 Sensor 2​
11​
0.8 TN/WH​
3121​
HO2S Low Signal – Bank 1 Sensor 2​
12​
0.35 OG/BK​
380​
A/C Refrigerant Pressure Sensor Signal​
13​
0.35 TN​
5514​
Low Reference​
14–15​
Not Used​
16​
0.35 PU​
1589​
Fuel Level Sensor Signal – Primary​
17​
0.35 D-BU​
473​
High Speed Cooling Fan Relay Control​
18​
0.35 BN​
4​
Ignition Voltage​
19​
0.35 PK​
639​
Ignition Voltage​
20​
0.35 RD/WH​
540​
Battery Positive Voltage​
21–22​
Not Used​
23​
0.35 PU​
1272​
Low Reference​
24​
0.35 D-GN​
890​
Fuel Tank Pressure Sensor Signal​
25–26​
Not Used​
27​
0.35 TN​
2501​
High Speed GMLAN Serial Data Bus (−)​
28​
0.35 TN/BK​
2500​
High Speed GMLAN Serial Data Bus (+)​
29​
0.35 D-BU​
1161​
Accelerator Pedal Position (APP) Sensor 1 Signal​
30​
0.35 BN​
1271​
Low Reference​
31​
0.35 OG/BK​
1057​
Low Reference​
32​
0.35 L-BU​
1162​
Accelerator Pedal Position (APP) Sensor 2 Signal​
33​
0.35 GY​
705​
5-Volt Reference 1​
34​
0.35 GY​
2700​
5-Volt Reference 1​
35​
Not Used​
36​
0.35 TN​
1274​
5-Volt Reference 1​
37​
0.5 TN​
472​
Intake Air Temperature (IAT) Sensor Signal​
38​
0.5 TN/BK​
2760​
Low Reference​
39–40​
Not Used​
41​
0.5 YE​
492​
Mass Air Flow (MAF) Sensor Signal​
42–46​
Not Used​
47​
0.8 PK/BK​
5290​
Ignition Voltage​
48​
0.35 BN​
818​
Vehicle Speed Signal (VSS)​
49​
0.8 TN​
3221​
HO2S Low Signal – Bank 2 Sensor 2​
50​
0.35 D-GN/WH​
465​
Fuel Pump Relay Control – Primary​
51​
Not Used​
52​
0.35 PU/WH​
6386​
Starter Relay Coil Control​
53–55​
Not Used​
56​
0.35 WH/BK​
1164​
5-Volt Reference 2​
57​
Not Used​
58​
0.35 D-GN​
335​
Low Speed Cooling Fan Relay Control​
59​
0.35 BN​
5069​
Main Relay Coil Control​
60​
0.35 TN​
2759​
Low Reference​
61​
0.35 WH​
1310​
EVAP Canister Vent Solenoid Control​
62​
Not Used​
63​
0.35 D-GN/WH​
459​
A/C Compressor Clutch Relay Control​
64​
0.35 OG/WH​
3223​
HO2S Heater Low Control – Bank 2 Sensor 2​
65​
0.35 GY/WH​
3122​
HO2S Heater Low Control – Bank 1 Sensor 2​
66–67​
Not Used​
68​
0.35 BN/WH​
419​
Malfunction Indicator Lamp (MIL) Control​
69​
0.8 PU​
3220​
HO2S High Signal – Bank 2 Sensor 2​
70–72​
Not Used​
73​
2 BK/WH​
451​
Ground​
1 - 1 of 1 Posts
