Hello everyone,I have a 06 g6 gtp 3.9 liter automatic,no drive on take off? Manual shift have to take off in 2nd hard shift to 3rd an 4th smooth even goes on into drive,if u slow down in drive won't pull anymore? An if you stay in manual shift as u go to stop it will jolt into low gear an throw u forward? No leaks can't get code to pull up ?help
These are the symptoms I had when the first gear band broke.
You may need a transaxle...
  1. Was told it could be cooler lines under screen in pan cracked? Not holding pressure enuff to shift? I replaced all trans mounts an engine mount? Then the hard shift started,hard went to no drive,but can manual shift all way up from 1st to 4th then drive?i
Pretty sure that if internal lines are cracked you only have reverse . If no codes I doubt the solenoids have failed . That leaves failed clutches .
Just had this issue on my 2006 G6 GT. Mechanic replaced all shift solenoids the first time, & 6 months later the valve body & 1st & 2and shift solenoid
