1 - 14 of 14 Posts
on a 2006 g6 gtp
engine starts when key is inserted without turning.( relay under hood chatters)
runs about 5 seconds,then turns off. remote start has been disabled.
i can then restart ok. any suggestions please
thanks [email protected]
this problem has been going on for about six months and happens
about 50 percent of the time.
Wish I could help you bro. I had a starter problem that was randomly it would crank slowly and wouldn't start unless I pressed the gas. To fix it, I cleaned the throttle body. Three days and it hasn't had a problem again yet.
Have you tried a different key? Reflash the computer? I don't know a whole lot about cars but it sounds like you have more of a computer/electrical than mechanical problem. Maybe when they disconnected the remote start something got crossed. Take it back to whoever did that and talk to them?
Why did you disconnect remote start? Just wondering.
on a 2006 g6 gtp
Does it have factory or aftermarket remote start in that car?
Start relay #31 in the underhood fuse block is chattering?
Expand on this statement: "remote start has been disabled"
The remote start is factory installed and works fine with both keys.
I disabled the remote start with the menu on the computer.
I also tryed some wd -40 in the key slot with no luck.
I have not replaced the starter relay.how ever i could.
I also called a couple of gm dealers ankd they claim never to have seen this problem.
Discussion Starter #8
i will swap it out to night
also fyi
on a few occasions when key is inserted and
turned to acc nothing on dash turns on
then turned to on nothing
then turned to start nothing
when i remove key and reinsert all turns on and engine starts
thanks for all your help GREENMAN
frank
frank
It has to be the ignition switch then. That's covered in the Chiltons for G6.
I think he's referring to the electric part of the lock vs the mechanical part of the lock. I'd say the electrical parts. I.E. the switch behind the key'd lock
I would assume it's easier getting to the assembly with it being in the dash, As opposed to being in the steering column. Just larger panels to remove...
1 - 14 of 14 Posts
