Love the enthusiasm... But I really don't see where this is possible... The engine, size wise would probably fit but the problem is going to come down to the transmission and more importantly the computers required to run it. The transmission you have will obviously not handle that kind of power. You need to get your hands on a 6T80 transmission to handle that power even then your pushing the limits of that transmission. Now the problem about the computers... TCM swap and ECU swap will be hard if not impossible. Especially with these new twin turbo engines take it from the Ford Ecoboost guys; Its not only extremely difficult but extremely expensive to swap these new high performance twin turbo engines into cars. An Ecoboost swapped Raptor F-150 costed over 30000 to swap. Those are just a couple problems that you will probably run into. Not to be a downer but I'm sure even if you somehow figured ways around these problems you will run into more and it will not be worth it. Not to let you down or anything it's just my .02 cents.
