My friend and I are trying to swap his engine out of his 2009 GXP
So this is what happened, the engine died on him on the freeway
Got it towed home, then he started looking for a used engine on craigslist
He called me and was happy he found one cheap
When he got it home the engine are different
So he called the guy back and the guy told him that the engine came out of a 2009 g8 but it would fit the G6 with a few mods
Will it work?
Will it be a lot of work getting it to work?
Thanks
2007 gt retractable
im assuming a g8 engine will be a v8.thats not going to work.unless the first engine blew up id get it fixed
The G8 was available with a 3.6 V6 and a two V8's. It was also a rear wheel drive. The 3.6 was the same engine used in 08-09 G6 GXP.
Don't know what mods would need to be made.
Discussion Starter · #4 ·
Yes , it is the v6 3.6 same engines except of course the G8 its a fwd and the G6 rwd
Sorry for the late reply , went out of town for the weekend
Dang he really needs to get this car going
Hope someone here tried this engine swap
Thanks again
Pics of the donor engine and your broken engine please. If the blocks are the same then all you would need to do is swap all your electronic controls if they are different to the donor engine. If the intakes is different then you will have to swap that also. good luck. TPS, CAM, VV, Coils...
