1 - 17 of 17 Posts
I have 2008 Pontiac G6 GXP 3.6 L car won’t start says error on Odometer won’t even crank ran the night before went out to start the next morning not even a crank the needles jump then go back to zero and that’s itThe security lights not on the check engine lights on but it has been for a while any ideas?
First thing I would say is check your battery contacts for oxidization and clean them. When did you buy the battery last? Then if you can, find out if your alternator still has output, I would wager it's the alternator or starter.
I have checked the battery, and it’s only a couple months old. I took it to a garage to be hooked up and they said they couldn’t get any communication with it that they must be a wire disconnected but I can’t find any so I don’t know what else to do
· Super Moderator
If it were me I would suspect a blown fuse that was powering something important. I would check the fuses individually with an ohm meter or some other tester. If you find a blown fuse you might also consider that they usually blow for a reason. Make sure you only replace with the correct amp rating and if it blows again you will need to dig deeper into why.
Another option you may want to consider is that the big multi pin connectors on the BCM (and possibly the ECU) have been shown to have connectivity issues that cause problems. Applying dielectric grease generously to the holes on the connector where the pins go in (spread it an push some into the pin holes with your finger) has been known to improve the situation. From what you describe I would be thinking fuses first. Just my thinking, clearly it could be pretty much anything at this stage.
Hope you get it fixed.
I have an 09 and seem to be having the same issue. The battery is only 4 months old.
I am also having the odo say "Error" as well as the screen above the radio state "Service airbag, Service TCS, and Service power steering"
I tried jumping it at first thinking something had just drained the battery. It did start up but when I turned it off 5 min later it never restarted. Since then I have been checking fuses/relays and looking through forums to see if there was someone else having the same issues. I even went to LKQ found another ecm and did the steps to program the key to it. Still nothing. Any help or even direction to someone that can help would be super appreciated.
If I figure something out I will be sure to come back and let you all know
Steven definitely a gremlin in your electronics. Sounds very much like a short somewhere. Look around your computer modules under the hood and see if you can find where any wires are rubbing or corroded.
I took the morning to see if I could locate a short or damaged wire. I was not able to find anything concerning. I double checked all the fuses and relays. At this point im about to call it and get it towed to the nearest GM dealer sometime next week. I dont have the time to be messing with this.
Alright I have a follow up for my G6. I ended up taking the car to a dealership because I got tired of messing with it. Turns out there was an issue with a harness. There was a short going to OnStar that caused the ECM to go bad. That is what the rep told me at the dealership. I have my doubts but the ECM is new and the car is running again. They said that the tech fixed the short so hopefully this does not happen again.
Any questions let me know and ill answer them as best as I can.
Thanks Guys
Thanks Guys
Which harness was at fault? And did they find the short there? I may have the same problem. And if I could find out which one hopefully I’ll be able to fix it with out taking it to dealer.
I just got a new battery they cleaned all the posts and had it looking like new.. Then my error was showing on my odometer and abs and tr lights all lite up. Driving as rough as a cab, called my ex- husband and he says it's my alternator. I got it home have triple AAA so I can have it towed to somewhere. I live in Chandler Az and so many mechanics speak Spanish and I don't. Besides the dealership any suggestions from anyone?
· Super Moderator
Checking the alternator is fairly simple if you have a multimeter. With the car off you should get just under 12v DC across the battery terminals. With the engine running this should increase to a little higher than 13v.
If it were my car, the first thing I would do is add dielectric grease to the BCM and PCM connectors. The BCM is the more likely culprit as it had a recall for related issues. If that did not work I would check and potentially replace the grounds from the battery as these have been known to rot out. Hope this helps.
Alright I have a follow up for my G6. I ended up taking the car to a dealership because I got tired of messing with it. Turns out there was an issue with a harness. There was a short going to OnStar that caused the ECM to go bad. That is what the rep told me at the dealership. I have my doubts but the ECM is new and the car is running again. They said that the tech fixed the short so hopefully this does not happen again. Any questions let me know and ill answer them as best as I can. Thanks Guys
Did you have to pay ?
Thanks Guys
1 - 17 of 17 Posts
