Does anyone know I have a 2009 gxp and when i shut the car of the fan continues to run or even turn on if it isn't running already. I have had the car for two years and been through two summers and don't ever recall experiencing this up until approx. 2 weeks ago. Anyone else have this happen? Is it normal or possibly a bed sensor or relay? I have no codes and no engine lights on.
Yeah, sounds like the engine is running hot (as greenman said) If the engine is in fact not running hot and is still doing this it could be a coolant temp sensor. My grand am acted up like that. As soon as the key was turned the fans kicked on, temp gauge shot to red, and the idling was as if I had a blown head. Replaced a $10 sensor in it and straightened right up. It is something to at least check. A way of testing it is to unplug the sensor (car will run a bit bad) but if the fans straighten up you'll know that is the problem. Just some ideas man. not the best of mechanical and am only speaking from experience. :)
Without ECT sensor input the fans will run constant with the engine running.
Ahh. I did not know that the fans would run constant on these cars with the sensor unplugged. Thanks for clearing it up man :)
OK i think it was just a low coolant issue. i topped the overflow off and they haven't come back on. BTW unplugging the ect sensor does not turn the fans on. It probably works opposite if the sensor goes bad it probably closes the circuit and the fans would stay on I didn't try jumping the terminals though but that would rule it out.
If the level was low, you probably have a leak. How much did you have to add?
I'll have to do some research on that finding. Computer control has gotten very complex.
