2006 GTP G6 3.9l v6 2 Door Coup
Hiya all. Since I've had my G6 I've had to replace a few things. The radiator, and now the fuel pump (was leaking like almost all original models did)
My radio display still shows "Low Coolant" everytime I start up. The coolant level is right where it should be so was wondering if there was a way to turn that off?
When I replaced my fuel pump either the float fell off or is wedged between a hose or something so the Gas gauge is always on E. That's no problem.. I can live with that.. but is there a way to stop the radio from displaying "low fuel" and "low fuel range" ?
Thanks all
Nope, You need to go back and check the sensors/fuel level float. Yeah, a big job to drop the fuel tank again, but the sensor for coolant should not be near as bad to access.
Good Luck! ;)
...or you could disconnect power from the radio. That would also remove all displayed warnings, chimes and annoyances but does come with its own down sides :(
