1 - 9 of 9 Posts
SullyG6
So I bought some LED's and have them wired up to the fuse box on the passenger side of the car....is there a way I can wire them so that when i hit the fog light button they come on with the fog lights? and just for fun, is there a way i could make them blink for a turn signal?
Thanks to all replies ;)
You can just wire the LED's parallel inside the foglight circuit and they will come on with them. Same thing if you want them as turn signals. But if you want them to do both you're going to have to get pretty fancy with wiring and relays and what not.
SullyG6
ok cool, thanks....so to wire them in parallel with the fog lights all i have to do is join the positive and negative connections with the positive and negative connections in each fog light?
pretty much. its really just taping into the wiring.
Good stuff!
1 - 9 of 9 Posts
