I have an 06 G6 and both front doors make a horrible popping/creaking noise when they are opened... im planning on taking it in but want to know if i can fix her up easy without the hassle of taking it in and talking to idiots. If anyone knows what im talking about i would appreciate it greatly if you could help a girl out... like i said it makes a popping noise about 3 times.. the more you open the door the more pops it makes... Thanks!!:)
You can lubricate the hinges, but i would not recommend doing it to the stopper, because it won't do it's job and just let the door swing open and closed.
okay well thanks for the help :) i will tighten the bolts like you said and see if that helps. much thanks!!!
