I have a '06 g6 gtp with 160k miles. It developed a problem in the front end, it would pull real hard into a left hand turn after turning the steering wheel a certain distance and some clunking noise. I replaced both front struts and sway bar links. one of the way bar links was bad causing the noise. Took the car to sears for an alignment and afterwards the car is driving even worse. Take it back too sears to see if they can figure the problem out. Diagnose the driver's side lower control arm is bad and demonstrate the problem to me. They then replace that and say the car is good but all the engine mounts are real bad. I pay and drive home. The car is still doing the turning thing and now pulls to the left when applying the brakes. It will also pull the steering wheel to the left while accelerating. My question is will all the engine mounts being bad cause the steering issues? If not then what else could be the problem? Thanx in advance.
