wont move front back up or down , what might be wrong
it was working fine , i moved then again and it didnt go , were in the trunk
Rear fuse box. You might have just overstretched a harness connector. You will need to take a careful look. IIRC, the harness has been able to get pinched in the tracks on occasion in these vehicles. That should be apparent when you look but you may have to pull the seat out to really look over the harness & connector. Could also be the seat adjuster switch. If the fuse is not open (though I bet that it is) that would tell you something also.
ok will check it out , if not ill update tomorrow
thanks
