1 - 13 of 13 Posts
I recently buy a 2006 G6 COUPE GTP. I SAW THAT THE CAR IS A LITTLE BIT HIGH AND MOST IN THE REAR WHEELS. THIS CAR COMES WITH SPORT TUNED SUSPENSION BUT I WANT SOMETHING TO LOWER THE CAR JUST A LITTLE BIT MORE.
I READ SOMETHING ABOUT EIBACH PRO-KIT BUT I WANT A KNOW IF SOMEONE HERE USED THAT AND A PICTURE WOULD BE GREAT.
Are you planning on keeping the stock rims? I believe the Eibach kit drops the rear 1.2 or 1.3. I'm not sure there's enough room in the wheel well to do that without rolling the fender, or going with a smaller wheel. I agree, it does sit a little too high for my taste too. Maybe some side skirts would help make it appear lower? Razzi has a nice looking ground effects kit.
By the way, turn your caps lock off. It's difficult to read and some take it as you're yelling. Welcome to the board!
i think there is plenty room for that drop...not sure about the GTP though, on the GT there is. Wonder if anyone has purchased springs yet...
jeff
Designed For Action
H & R will have their lowering springs out in March. The drop is 1.5" /front - 1.3" / rear. You can go with a 1.5" drop without issues. :)
  • Like
Reactions: Madelynne19
Well, I just measured the rear wheel gap and there's just under 2 inches from the tire to the edge of the fender. I wouldn't feel comfortable with only a half inch of clearance. Better watch out for pot holes.
You all did see G6_Coupe_PR was asking about the GTP, which comes with 18's right? That won't matter if the OD are the same on the 17s and 18s? I don't know if they are or not?
Designed For Action
The OD should be very close. Potholes will not be a problem, unless you go for tires with 'rubberband width' sidewalls. I trust H&R springs, because I had them on my GA GT and never had any issues.
Designed For Action
GTPGuy82 said:
I'd think the drop in the rear would be more than in the front, since it's already way high up.
Mike
H&R builds springs with a lower front drop to maintain the 'Rake angle' of the car. This was told to me by one of the top guys at the company.
1 - 13 of 13 Posts
