Pano sunroof stuck....
My panoramic sunroof is stuck shut (only after being stuck open for a bit...). It wasn't opening properly for a while and I had to manually pop the first tile up before the rest would slide back. I figured it just needed to be lubricated but even after lubricating it, the first panel wouldn't pop up. Then the back panel started sticking but when I went around to the back and gave it a little help it would pop up and work fine... Then one day I had it open and went to close it and it started to close then opened itself back up. After playing with it for a little while it finally shut... on the weather seal. So now the weather seal is stuck under the back panel and it won't go all the way down. Its still leak proof, just the panel sticks up a few cm. After that happened, I haven't been able to get it back open. It tries to open (it makes noises) but then it doesn't. I've tried helping it a little by pushing up the first panel like I normally do but its sticking really hard and I don't want to break it... Any suggestions?
