Hello,
So I recently purchased a 09 G6 Convertible and it started to vibrate when driving over 40mph.
I was told to change tires, and tie rods. I purchased a set of 4 brand new tires, replaced both tie rods and alignment completed. Car still vibrates over 40mph. What else does it need?
KarenF5
Double check that tires are properly balanced. Also check for bent rim. If that is fine, then take it to another mechanic for a check. I had put a control arm on my car and continued having issue. Turned out part was defective, but was not found until I took it elsewhere and told them what I had done and the issue.
08 convertible
Karen, take the car to a competent shop. Or a tire store with a good reputation. Replacing parts at random because "you were told" is a good way to throw away money. Tell the shop to fix the problem and don't pay if they don't.
