Hello
I recently got a new remote for my 2005 G6 and when I took it to the dealership to get programmed, I was told that it couldnt be programed because my car could not communicate with the computer. He told me that it was something wrong with the wires and that it would be $90 to just look at it.. So I was just wondering if any of you have ever heard of this and what you suggest that I should do??
And also a couple of months ago my brake light was staying on whenever I turned the car off but it stopped after a couple of days.
So Im sure there could be something wrong with some wires but I just need some advice.
That can get complicated.
If what they were saying is the scan tool would not power on then you have a problem with either the DLC connector B+ (terminal 16) or ground (terminal 4). Easy enough to verify those.
If what they were saying was that the scan tool would not communicate with one or more modules you don't have much of a prayer of fixing that yourself.
http://www.g6ownersclub.com/forum/attachment.php?attachmentid=2768&stc=1&d=1330806429
Hello
I had the same problem with my 2006 Pontiac G6. After conducting research online I discovered that just simply removing both the PCM and BCM connections, spray the pins with electronic cleaner, let dry, apply dielectric grease and then reconnect. My car was then able to connect to my scanner and it connected to the scanner at the mechanic's shop.
I would be tempted to go and buy a cheap scan tool and see if it will connect to my car's system. If it does it means you were being lied to at that dealership. Remember....auto repair is a thug industry.
