Gooday All,
Just a general question which no one has seemed to raise yet in this forum. While the base V6 sedan gets 22/32 MPG, I've noticed that the GT models are slightly lower, at 21/29. This seems hard to explain, since both models are the same weight, same engine, etc. Could the manual shift mode on the GT models be causing this? I suppose if you shift through the gears manually you might burn more gas, and its possible that whoever determines these figures is accounting for that. Any experts out there with a professional opinion?? thanks.
The difference is due to the axle ratio.
The GT has a higher ratio, causing the engine to spin at a slightly higher RPM at any given speed.
Their 29mpg highway is way off for the GT. At 75mph, I get a consistent 32mpg.
