hey, I was going to make a little list about some G6 things..
like stock gear ratio, synchro operation.. and such, so here.. let me go at it!
now this is all from service information, so its all correct, this is not of my personal experience.
6 speed operation:
The manual 6 speed gearbox has synchronizers on all gears, including reverse. To improve synchronization, the hub for 1st/2nd has three cones. 3rd/4th and reverse has a double cone, and 5th/6th has a single cone.
The gearbox has two output shafts. The lower shaft transfers power for 1st, 2nd, 5th, 6th and reverse gears. The upper output shaft transfers power for 3rd, 4th and reverse gears. This means that both intermediate shafts have a pinion gear that is constantly meshed with the crown wheel.
The components of the synchronizer are as follows:
• Hub (1)
• Synchronizer sleeve (2)
• Outer synchronizer cone (3)
• Intermediate synchronizer cone (4)
• Inner synchronizer cone (5)
• Insert (6)
• Ball (7)
• Spring (8)
If 1st or 2nd gear is engaged, the sleeve pulls the inserts slightly, which then start to bear against the outer baulk ring. This produces a pre-synchronization that is advantageous for the continued synchronization/shifting. In this position, the ball is pressed down against the sleeve. The ball does not reach a new recess in the sleeve. Instead, the forces required to keep the gear engaged primarily come from segments in the gear selector mechanism. This function can be found in all synchronizer hubs.
When counting the synchronizer cones, start from the shaft.
The design of the gear box, with double intermediate shafts, means that the gear box is short, compact and very torsionally stiff. The gear box is designed to be able to continuously transfer 400 N·m of torque.
Note that the gears on the input shaft are called pinions, driving gears. The gears on the output shaft are called gear wheels, driven gears.
In 1st gear range, power is transmitted via the 1st gear pinion, fixed on the output shaft, to output shaft 1. 1st gear wheel is locked to the output shaft 1, on which it is journalled, by the 1st/2nd synchronizer sleeve.
In 2nd gear range, power is transmitted via the 2nd gear pinion, fixed on the input shaft, to output shaft 1. 2nd gear wheel is locked to the output shaft 1, on which it is journalled, by the 1st/2nd synchronizer sleeve.
In 3rd gear range, power is transmitted via the 3rd/5th gear pinion, which is pressed over a splined joint on the input shaft, to output shaft 2. 3rd gear wheel is locked to the output shaft 2, on which it is journalled, by the 3rd/4th synchronizer sleeve
In 4th gear range, power is transmitted via the 4th gear pinion, which is pressed over a splined joint on the input shaft, to output shaft 2. 4th gear wheel is locked to the output shaft 2, on which it is journalled, by the 3rd/4th synchronizer sleeve.
In 5th gear range, power is transmitted via the 3rd/5th gear pinion, which is pressed over a splined joint on the input shaft, to output shaft 2. 5th gear wheel is locked to the output shaft 1, on which it is journalled, by the 5th/6th synchronizer sleeve.
In 6th gear range, power is transmitted via the 6th gear pinion, which is pressed over a splined joint on the input shaft, to output shaft 1. 6th gear wheel is locked to the output shaft 1, on which it is journalled, by the 5th/6th synchronizer sleeve.
In reverse gear range, the power is transmitted from the 1st gear pinion on the input shaft to the 1st gear wheel on the lower output shaft. This is in constant mesh with the reverse gear wheel that is journalled on the upper output shaft. When the reverse gear sleeve locks the reverse gear wheel to the output shaft, reverse is achieved with the 1st gear wheel acting as an idler gear.
Gear
MT2 Ratio (1:1), MU9 Ratio (1:1)
FIRST
3.77, 3.77
SECOND
2.04, 2.04
THIRD
1.32, 1.37
FOURTH
0.95, 1.05
FIFTH
0.76, 0.85
SIXTH
0.62, 0.71
REVERSE
3.54, 3.54
Fluids
Trans
Fluid Capacity Specifications (4T45-E) Application
Bottom Pan Removal
6.5 liters
6.9 quarts
Complete Overhaul
9.0 liters
9.5 quarts
Dry
12.2 liters
12.9 quarts
Fluid Capacity Specifications (4T65-E) Application
Bottom Pan Removal
7.0 liters
7.4 quarts
Complete Overhaul
9.5 liters
10.0 quarts
Dry
12.7 liters
13.4 quarts
Discussion Starter · #2 ·
Engine Specs 2.4L
General Data
Engine Type
Inline 4 Cylinder
Displacement
2.4 L
146 CID
RPO
LE5
Liter (VIN)
B
Bore
87.992-88.008 mm
3.4668-3.4675 in
Stroke
98 mm
3.861 in
Compression Ratio
10:01
Balance Shaft
Bearing Clearance
0.030-0.063 mm
0.0012-0.0025 in
Bearing Diameter - Inside - Carrier
20.050-20.063 mm
0.7894-0.7899 in
Bearing Diameter - Outside - Carrier
41.975-41.995 mm
1.6526-1.6534 in
Bearing Journal Diameter
20.000-20.020 mm
0.7874-0.7882 in
Bushing Clearance
0.033-0.102 mm
0.0013-0.0040 in
Bushing Diameter - Inside
36.776-36.825 mm
1.4479-1.4498 in
Bushing Journal Diameter
36.723-36.743 mm
1.4458-1.4466 in
End Play
0.100-0.300 mm
0.0020-0.0118 in
Block
Balance Shaft Bearing Bore Diameter - Carrier
42.000-42.016 mm
1.6535-1.6542 in
Balance Shaft Bushing Bore Diameter
40.763-40.776 mm
1.6048-1.6054 in
Crankshaft Main Bearing Bore Diameter
64.068-64.082 mm
2.5224-2.5229 in
Cylinder Bore Diameter
87.992-88.008 mm
3.4668-3.4675 in
Cylinder Bore Out-of-Round - Maximum
0.010 mm
0.0004 in
Cylinder Bore Taper - Maximum
0.010 mm
0.0004 in
Cylinder Head Deck Surface Flatness - Longitude
0.050 mm
0.002 in
Cylinder Head Deck Surface Flatness - Overall
0.08 mm
0.0031 in
Cylinder Head Deck Surface Flatness - Transverse
0.030 mm
0.0012 in
Camshaft
Camshaft End Play
0.040-0.144 mm
0.0016-0.0057 in
Camshaft Journal Diameter
26.935-26.960 mm
1.0604-1.0614 in
Camshaft Thrust Surface
21.000-21.052 mm
0.8268-0.8252 in
Connecting Rod
Connecting Rod Bearing Clearance
0.029-0.069 mm
0.0011-0.0027 in
Connecting Rod Bore Diameter - Bearing End
52.118-52.134 mm
2.0519-2.05252 in
Connecting Rod Bore Diameter - Pin End
20.007-20.021 mm
0.7877-0.7882 in
Connecting Rod Side Clearance
0.070-0.370 mm
0.0028-0.0146 in
Connecting Rod Straightness - Bend - Maximum
0.021 mm
0.0083 in
Connecting Rod Straightness - Twist - Maximum
0.04 mm
0.0157 in
Crankshaft
Connecting Rod Journal Diameter
49.000-49.014 mm
1.9291-1.9297 in
Crankshaft End Play
0.050-0.380 mm
0.0012-0.0150 in
Crankshaft Main Bearing Clearance
0.031-0.067 mm
0.0012-0.0026 in
Crankshaft Main Journal Diameter
55.994-56.008 mm
2.2045-2.2050 in
Cylinder Head
Surface Flatness - Block Deck - Longitude
0.050 mm
0.002 in
Surface Flatness - Block Deck - Overall
0.1 mm
0.004 in
Surface Flatness - Block Deck - Transverse
0.030 mm
0.0012 in
Valve Guide Bore - Exhaust
6.000-6.012 mm
0.2362-0.2367 in
Valve Guide Bore - Intake
6.000-6.012 mm
0.2362-0.2367 in
Valve Lifter Bore Diameter - Stationary Lash Adjusters
12.013-12.037 mm
0.4730-0.4739 in
Lubrication System
Oil Pressure - Minimum - @1000 RPM
344.75-551.60 kPa
50-80 psi
Oil Capacity
4.8L
5.0 quarts
Piston Rings
Piston Ring End Gap - First Compression Ring
0.20-0.40 mm
0.008-0.016 in
Piston Ring End Gap - Second Compression Ring
0.35-0.55 mm
0.014-0.022 in
Piston Ring End Gap - Oil Control Ring - Rails
0.25-0.76 mm
0.010-0.030 in
Piston Ring to Groove Clearance - First Compression Ring
0.04-0.08 mm
0.0015-0.0031 in
Piston Ring to Groove Clearance - Second Compression Ring
0.030-0.069 mm
0.0012-0.0027 in
Piston Ring to Groove Clearance - Oil Control Ring
0.090-0.106 mm
0.0035-0.0042 in
Piston Ring Thickness - First Compression Ring
1.170-1.190 mm
0.0461-0.0469 in
Piston Ring Thickness - Second Compression Ring
1.471-1.490 mm
0.0579-0.0587 in
Piston Ring Thickness - Oil Control Ring - Rail - Maximum
0.43 mm
0.0169 in
Piston Ring Thickness - Oil Control Ring - Spacer
1.574-1.651 mm
0.0620-0.0650 in
Pistons and Pins
Pin - Piston Pin Clearance to Connecting Rod Bore
0.007-0.026 mm
0.0003-0.0010 in
Pin - Piston Pin Clearance to Piston Pin Bore
0.002-0.012 mm
0.0001-0.0005 in
Pin - Piston Pin Diameter
19.995-20.000 mm
0.7872-0.7874 in
Pin - Piston Pin End Play
0.19-1.16 mm
0.0075-0.0461 in
Piston - Piston Diameter - @14.5 mm up
85.967-85.982 mm
3.3845-3.3851 in
Piston - Piston Pin Bore Diameter
20.002-20.007 mm
0.07875-0.7877 in
Piston - Piston Ring Grove Width - Oil Control
2.52-2.54 mm
0.0992-0.1000 in
Piston - Piston Ring Grove Width - Second
1.52-1.54 mm
0.0598-0.0606 in
Piston - Piston Ring Grove Width - Top
1.23-1.25 mm
0.0484-0.0492 in
Piston - Piston to Bore Clearance
0.010-0.041 mm
0.0004-0.0016 in
Valve System
Valves - Valve Face Runout - Maximum
0.04 mm
0.0016 in
Valves - Valve Seat Runout - Maximum
0.05 mm
0.0020 in
Valves - Valve Stem Diameter - Exhaust
5.935-5.950 mm
0.2337-0.2343 in
Valves - Valve Stem Diameter - Intake
5.955-5.970 mm
0.2344-0.2355 in
Valves - Valve Stem to Guide Clearance - Exhaust
0.050-0.077 mm
0.0020-0.0026 in
Valves - Valve Stem to Guide Clearance - Intake
0.030-0.057 mm
0.0012-0.0022 in
Valve Lifters - Valve Lifter Diameter - Stationary Lash Adjuster
11.986-12.000 mm
0.0005-0.0020 in
Valve Lifters - Valve Lifter-to-Bore Clearance - Stationary Lash Adjuster
0.013-0.051 mm
3.2210-3.2299 in
Valve Springs - Valve Spring Load - Closed - @22.5 mm
525.0-575.0 N. - Eng Spec.
Valve Springs - Valve Spring Load - Open - @32.5 mm
245.0-271.0 N. - Eng Spec
Engine Specs 3.5L
General Data
Engine Type
60 degree V-6
Displacement
3.5L
214 cu in
RPO
LX9
VIN
8
Bore
94 mm
3.70 in
Stroke
84 mm
3.31 in
Compression Ratio
9.8:1
Firing Order
123456
Spark Plug Gap
1.52 mm
0.060 in
Block
Camshaft Bearing Bore Diameter - Front and Rear
51.03-51.08 mm
2.009-2.011 in
Camshaft Bearing Bore Diameter - Middle #2, #3
50.77-50.82 mm
1.999-2.001 in
72.1535-72.1695 mm
2.840-2.841 in
Crankshaft Main Bearing Bore Out-of-Round
0.008 mm
0.00031 in
93.991-94.009 mm
3.700-3.701 in
Cylinder Bore Out-of-Round - Diameter - Production
0.020 mm
0.0008 in
Cylinder Bore Out-of-Round - Diameter - Service
0.025 mm
0.001 in
Cylinder Bore Taper - Production
0.020 mm
0.0008 in
Cylinder Bore Taper - Service
0.025 mm
0.001 in
Cylinder Head Deck Height
224 mm
8.818 in
0.05 mm per 152 mm
0.0019 in per 6 in
21.417-21.455 mm
0.843-0.844 in
Camshaft
Camshaft Bearing Inside Diameter
47.516-47.541 mm
1.871-1.872 in
47.443-47.468 mm
1.868-1.869 in
Camshaft Journal Out-of-Round
0.003 mm
0.0001 in
Camshaft Lobe Lift - Exhaust
6.9263 mm
0.2727 in
Camshaft Lobe Lift - Intake
6.9263 mm
0.2727 in
Cooling System
Capacity
12.4 liters
13.1 quarts
Thermostat Full Open Temperature
195 degrees
Connecting Rod
0.18-0.062 mm
0.0007-0.017 in
60.322-60.338 mm
2.375-2.376 in
Connecting Rod Bore Out-of-Round
0.006 mm
0.00023 in
57.122-57.138 mm
2.249-2.250 in
Connecting Rod Length - Center to Center
150 mm
5.9 in
0.200-0.241 mm
0.008-0.009 in
Crankshaft
57.122-57.138 mm
2.248-2.249 in
Connecting Rod Journal Out-of-Round
0.005 mm
0.0002 in
Connecting Rod Journal Taper
0.008 mm
0.0003 in
Connecting Rod Journal Width
21.92-22.08 mm
0.863-0.869 in
Crankshaft End Play
0.060-0.210 mm
0.0024-0.0083 in
0.019-0.064 mm
0.0008-0.0025 in
Crankshaft Main Bearing Journal Width
23.9-24.1 mm
0.941-0.949 in
67.239-67.257 mm
2.6473-2.6483 in
Crankshaft Main Journal Out-of-Round
0.005 mm
0.0002 in
Crankshaft Main Journal Taper
0.008 mm
0.0003 in
Crankshaft Rear Flange Runout
0.04 mm
0.0016 in
Cylinder Head
Combustion Chamber Depth - at Measurement Point
2.2 mm
0.087 in
Surface Finish - Maximum
2.8 RA
0.08 mm Per 152 mm
0.003 in Per 6 in
Surface Flatness - Exhaust Manifold Deck
0.1 mm
0.004 in
Surface Flatness - Intake Manifold Deck
0.1 mm
0.004 in
8.01 mm
0.315 in
8.01 mm
0.315 in
Valve Guide Installed Height
16.6 mm
0.654 in
Lubrication System
Oil Capacity - with Filter
3.8 liter
4.0 quarts
Oil Capacity - without Filter
3.3 liter
3.5 quarts
Oil Pressure - @ 1850 RPM
207-310 kPa
30-45 PSI
Oil Pump
Gear Diameter
38.05-38.10 mm
1.498-1.500 in
Gear Pocket - Depth
30.53-30.59 mm
1.202-1.204 in
Gear Pocket - Diameter
38.176-38.226 mm
1.503-1.505 in
Gears Lash
0.094-0.195 mm
0.0037-0.0077 in
Relief Valve-to-Bore Clearance
0.038-0.089 mm
0.0015-0.0035 in
Pin
Piston Pin Clearance to Connecting Rod Bore - Press Fit
-0.022 to +0.044 mm
-0.0008 to +0.0017 in
0.008-0.016 mm
0.0003-0.0006 in
Piston Pin Diameter
23.997-24.000 mm
0.9447-0.9448 in
Piston Pin Length
59.87-60.13 mm
2.35-2.36 in
Piston
Piston Diameter - production
93.980-94.020 mm
3.7-3.701 in
Piston Diameter - service limit
93.960 mm
3.699 in
24.008-24.013 mm
0.9452-0.9454 in
Piston Ring Groove Width
1.23-1.255 mm
0.048-0.049 in
Piston to Bore Clearance - production
-0.029 to +0.029 mm
-0.0011 to +0.011 in
Piston to Bore Clearance - service limit - Maximum
0.080 mm
0.003 in
Piston Ring End Gap
0.18-0.39 mm
0.007-0.015 in
0.48-0.74 mm
0.019-0.029 in
Oil Control Ring
0.25-0.74 mm
0.010-0.029 in
0.03-0.076 mm
0.001-0.003 in
0.04-0.078 mm
0.002-0.003 in
Oil Control Ring
0.09 mm
0.004 in
1.164-1.190 mm
0.046-0.047 in
1.472-1.490 mm
0.058 in
Oil Control Ring - Maximum
2.440 mm
0.096 in
Valves
Valve Face Angle
45 degrees
Valve Seat Angle
46 degrees
Valve Seat Depth - Exhaust - From Deck Face
8.9-9.1 mm
0.350-0.358 in
Valve Seat Depth - Intake - From Deck Face
7.9-8.1 mm
0.311-0.318 in
Valve Seat Width - Exhaust
1.70-2.0 mm
0.067-0.079 in
Valve Seat Width - Intake
1.55-1.80 mm
0.061-0.071 in
Valve Stem-to-Guide Clearance
0.026-0.068 mm
0.0010-0.0027 in
Valve Lifters/Push Rods
Push Rod Length - Exhaust
152.5 mm
6.0 in
Push Rod Length - Intake
144.2 mm
5.67 in
Valve Springs
Valve Spring Free Length
50.0 mm
1.91 in
Valve Spring Installed Height
44.2 mm
1.74 in
343 N @44.2 mm
77 lb 1.74 in
1041 N @33 mm
234 lb 1.299 in
Valve Spring Total Number of Coils
7.10
Discussion Starter · #4 ·
General Data
Engine Type
60 degree V-6
Displacement
3.9L
238 cu in
RPO
LZ9
VIN
1
Bore
99 mm
3.90 in
Stroke
84 mm
3.31 in
Compression Ratio
9.8:1
Firing Order
123456
Spark Plug Gap
1.00 mm
0.040 in
Block
55.26-55.31 mm
2.175-2.177 in
54.75-54.80 mm
2.155-2.157 in
72.1535-72.0695 mm
2.840-2.841 in
0.008 mm
0.00031 in
99.000-99.018 mm
3.897-3.898 in
0.026 mm
0.0010 in
0.030 mm
0.0011 in
0.026 mm
0.0010 in
0.030 mm
0.0011 in
224 mm
8.818 in
0.05 mm per 150 mm
0.0019 in per 5.905 in
21.417-21.455 mm
0.843-0.844 in
Camshaft
51.500-51.525 mm
2.028-2.029 in
51.415-51.440 mm
2.024-2.025 in
0.025 mm
0.001 in
6.9263 mm
0.2727 in
6.9263 mm
0.2727 in
Cooling System
Capacity
12.4 liters
13.1 quarts
195 degrees
Connecting Rod
0.18-0.062 mm
0.0007-0.017 in
60.322-60.338 mm
2.375-2.376 in
0.006 mm
0.00023 in
150 mm
5.9 in
0.200-0.241 mm
0.008-0.009 in
Crankshaft
57.122-57.138 mm
2.248-2.249 in
0.005 mm
0.0002 in
0.005 mm
0.0002 in
21.92-22.08 mm
0.863-0.869 in
Crankshaft End Play
0.060-0.210 mm
0.0024-0.0083 in
Crankshaft Main Bearing Clearance - Except #3
0.019-0.064 mm
0.0008-0.0025 in
Crankshaft Main Bearing Clearance - #3 Thrust Bearing
0.032-0.077 mm
0.0012-0.0030 in
0.005 mm
0.0002 in
0.005 mm
0.0002 in
0.04 mm
0.0016 in
Cylinder Head
2.2 mm
0.087 in
2.8 RA
0.08 mm per 152 mm
0.003 in per 6 in
0.1 mm
0.004 in
0.1 mm
0.004 in
8.01 mm
0.315 in
8.01 mm
0.315 in
16.6 mm
0.654 in
Lubrication System
3.8 liter
4.0 quarts
207-310 kPa
30-45 PSI
Oil Pump
Gear Diameter
38.05-38.10 mm
1.498-1.500 in
Gear Pocket - Depth
30.52-30.58 mm
1.202-1.204 in
38.176-38.226 mm
1.503-1.505 in
Gears Lash
0.094-0.195 mm
0.0037-0.0077 in
0.038-0.089 mm
0.0015-0.0035 in
Pin
-0.004 to -0.021 mm
-0.0001 to -0.0008 in
0.002-0.010 mm
0.00008-0.0004 in
Piston Pin Diameter
23.952-23.955 mm
0.942-0.943 in
Piston Pin Length
64.21-64.44 mm
2.57-2.53 in
Piston
Piston Diameter - Production
98.970-99.008 mm
3.896-3.897 in
Piston Diameter - Service Limit
98.950 mm
3.895 in
23.957-23.962 mm
0.943 in
1.22-1.24 mm
0.048-0.049 in
Piston to Bore Clearance - Production
-0.008 to +0.048 mm
-0.0003 to +0.0018 in
Piston to Bore Clearance - Service Limit - Maximum
0.080 mm
0.003 in
Piston Ring End Gap
0.15-0.30 mm
0.006-0.011 in
0.25-0.45 mm
0.009-0.017 in
Oil Control Ring
0.15-0.65 mm
0.06-0.025 in
0.03-0.065 mm
0.001-0.002 in
0.02-0.055 mm
0.0007-0.002 in
Oil Control Ring
0.01 mm
0.004 in
1.175-1.190 mm
0.046-0.047 in
1.475-1.490 mm
0.058 in
2.50 mm
0.098 in
Valves
Valve Face Angle
45 degrees
Valve Seat Angle
46 degrees
8.9-9.1 mm
0.350-0.358 in
7.9-8.1 mm
0.311-0.318 in
1.70-2.0 mm
0.067-0.079 in
1.55-1.80 mm
0.061-0.071 in
0.026-0.068 mm
0.0010-0.0027 in
146.0 mm
5.75 in
152.5 mm
6.0 in
Valve Springs
48.5 mm
1.89 in
43.2 mm
1.701 in
320 N 43.2 mm
75 lb 1.701 in
1036 N 32 mm
230 lb 1.260 in
6.55
Designed For Action
This is very good information! Thanks. This and your other post should be quite helpful. :)
Discussion Starter · #7 ·
no problem!
always glad to try and help out a bit!!!
if anyone needs anything else, just send me a PM and i can see if i can find it in service info!
or if you need to know how to do anything, like replace bulbs or take parts off i can get almost anything that you need!!
even keep you updated on bullitins!!
