Hi guys, I have an 06 G6 3.5l - yesterday I replaced the serp belt and idle pulley because I noticed a pulley was grinding. Afterward I realized the pulley that is actually grinding is to the right of the one I replaced. Can anyone tell me what this pulley goes to so I can properly identify the component and try to fix it?
Here is the routing diagram, #3 is what I replaced, #4 appears to be the actual culprit.
http://www.justanswer.com/uploads/ebrock63/2009-02-16_005358_10.png
Thanks!
-Eddy
Discussion Starter #2
Sorry guys, I hate to bump this already but this is becoming an issue and I'm afraid whatever it is will break soon and the grinding is loud and making everything vibrate. Any ideas what this is?
08 convertible
Eddy, I'm not sure what "pulley grinding" means, is the pulley itself rubbing against something? Or is the part behind the pulley making internal noises? I certainly would not drive a car that makes grinding noises. Whatever it is, it's very likely to cause expensive damage.
I can't tell what you have there, but the serp belt usually drives only the alternator, compressor and water pump. And PS pump if it has one. Plus a bunch of idler pulleys. So shouldn't be that difficult to tell by inspection what is behind the pulley that makes noise.
k, Yeah I googled water pump, and power steering pump but non of the images have the pulley I am referring to attached to the new part. The grinding noise is kind of like a metal scraping sounds - almost like a bad bearing, except the pulley I am pointing to.. I am not sure if that even has a bearing or not or if it directly spins a component such as the pump. The scraping causes the plastic guard (and other areas around the pulley) to vibrate.
I was trying to avoid pulling it all apart without first having the replacement - but it looks like I may need to just start taking things apart to diagnose the issue first.
If I took a few pictures, would that help you guys identify which component it is? I haven't any idea how to tell which is which.
08 convertible
The water pump doesn't look anything like an alternator or compressor. PS pump will have fluid hoses connected to it. So it shouldn't be hard to tell what it is. The size, shape and number of bolts on the pulley can vary greatly and doesn't always help you identify the device it's mounted to.
If it's the water pump and it grinds internally that would be pretty unusual. Normally when the bearing is shot it will leak coolant to alert you. But anything is possible.
