Part two
1. For 4, 5 and 6 cylinder engines, empty two of the 30 ml (1 oz) reservoirs of the GM Upper Engine and Fuel Injector Cleaner container into the J 35800-A - Injector Cleaning Tank then add 420 ml (14 oz) of regular unleaded gasoline. If you are using any other brand of cleaning tank, you will need a total of 60 ml (2 oz) mixed with 420 ml (14 oz) of regular unleaded gasoline.
2. For 8 cylinder engines, empty two of the 30 ml (1 oz) reservoirs of the GM Upper Engine and Fuel Injector Cleaner container into the J 35800-A - Injector Cleaning Tank then add 420 ml (14 oz) of regular unleaded gasoline. If you are using any other brand of cleaning tank, you will need a total of 60 ml (2 oz) of Upper Engine and Fuel Injector Cleaner mixed with 420 ml (14 oz) of regular unleaded gasoline. This procedure will need to be repeated for a second time for an 8 cylinder engine (8 cylinder engines receive 960 ml total fluid - 120 ml (4 oz) of Upper Engine and Fuel Injector Cleaner and 840 ml (28 oz) of gasoline.
3. Be sure to follow all additional instructions provided with the tool.
4. Electrically disable the vehicle fuel pump by either removing the fuel pump fuse or the fuel pump relay and disconnecting the oil pressure switch connector, if equipped.
5. Turn the ignition to the OFF position.
6. Relieve fuel pressure and disconnect the fuel feed and return lines at the fuel rail. Plug the fuel feed and return lines coming off the fuel rail with J 37287, J 42873 or J 42964 as appropriate for the fuel system.
7. Connect the J 35800-A to the vehicle fuel rail.
8. Pressurize the J 35800-A to 510 kPa (75 psi).
9. Start and idle the engine until it stalls, due to lack of fuel. This should take approximately 15-20 minutes.
10. Turn the ignition to the OFF position.
11. Disconnect the J 35800-A from the fuel rail.
12. Reconnect the vehicle fuel pump relay and oil pressure switch connector, if equipped.
13. Remove the J 37287, J 42873 or J 42964 and reconnect the vehicle fuel feed and return lines.
14. Start and idle the vehicle for an additional two minutes to ensure residual injector cleaner is flushed from the fuel rail and fuel lines.
15. Pour the entire contents of GM Fuel System Treatment Plus (P/N 88861011 [in Canada, P/N 88861012]) into the tank and advise the customer to fill the tank.
16. Review the benefits of using Top Tier Detergent gasoline with the customer and recommend that they add a bottle of GM Fuel System Treatment Plus to the fuel tank at every oil change. Regular use of GM Fuel System Treatment Plus should keep the customer from having to repeat the injector cleaning procedure.
17. Road test the vehicle to verify that the customer concern has been corrected.
Parts Information
Part Number
Description
Qty
88861802
GM Upper Engine and Fuel Injector Cleaner 473 ml (16 oz) Container (U.S.)
1*
88861804
GM Upper Engine and Fuel Injector Cleaner 473 ml Container (Canada)
1
88861011
Fuel System Treatment Plus 591 ml (20 oz) Container (U.S.)
1
88861012
Fuel System Treatment Plus 591 ml Container (Canada)
Parts Information
Part Number
Description
Qty
88861802
1*
88861804
1
88861011
1
88861012
