:confused:Didn't know if this was the right area or not, so please don't butcher me.
Now to move on to the problem. Just bought a Magnaflow Cat-Back.
ITCHING TO INSTALL!!!!!:eek:
Also, I don't want to pay for someone:mad: to do something I could just as easily do.
Now the big question: Does our exhaust have bolts that connect it? or do I simply have to saw the exhaust off
:confused:
Discussion Starter #2
Damn it...just opened the box my Magnaflow came in...it's definitely a cut 4'' back from the weld on the cat... son of a b****
Troy
i did it by myself. i have two ramps that i use to change my oil and i used those to raise my car, wasnt too hard to do myself!
I did mine myself. I just unbolted it from the flex pipe and cut the pipes by the back muffler to get them off.
Ah, good call. I'll unbolt it in the back first, then cut the pipe.
You sir, are a class act. Thank you.
I didnt have to cut anything. Unbolted the mid from the flex. Then the whole assembly just slips out of the little rubber mounts. I also bought the magnaflow single tip catback. So Idk what needs to be cut. You will prob need a new flange gasket. Mine crumbled to pieces. Besides that it was a real easy install even without a lift.
