the wires were pulled and in turn, melted the connector. it's not melted to anything.
i could have changed the damn bulb myself if i'd have known this would have happened
Laura,
Sorry to hear about your troubles. I do have a solution if you are willing to do it.
If you can't find a replacement plug you could just remove both male and female plugs from the headlight, and use what is called a dorman plug. I have had to do this on a few of my junk yard race cars.
A dorman plug (Auto Zone part number 85434) is a weather proof plug that has a male and a female end. See link.
http://www.autozone.com/autozone/ca...d=367-10&nysQFromType=&fromType=&pageNumber=7
Just scroll down to Dorman/Conduct-Tite 16-14 gauge .157 in. blue male and female bullet terminal set.
All you do is separate the plug, they come in 2 parts male and female as I said. Strip about 1/4 inch of the plastic insulation off the wire.
Twist the bare wire so it nice and straight with no strands sticking out sideways. If you have any stray strands sticking out from the twist it could touch other wires or metal and cause a short.
Insert the cleanly twisted wire into the dorman plug. NOTE: (the plastic insulation should just be touching the metal hole inside the dorman plug where the wire was inserted.)
Crimp the male end on the wires from the light assembly. If you don't have a wire crimping tool, a pair of needle nose pliers will work just fine.
Then crimp the female end on the wiring harness coming from the engine compartment the same way.
Just plug the wires together, red wire to red wire, green to green, black to black...ect as long as all the wire colors correspond or match each other.
Turn your lights on and check to make sure everything works, hi-low beam, blinkers, park lights...ect
If everything is ok with the lights I would suggest wrapping all the wires individually with electrical tape and then tie the wires all together. This will prevent any chaffing inside while driving.
This shouldn't cost more than $10 or $15 and about 1 or 2 hours of work.
Hope this helps.
