there was a recall on certain 6's so check that. if your g6 is not covered by the recall then it is the brake lamp switch. other problems she should occur are constant running exterior brake lamps and trouble shifting out of park (if this happens push the brake pedal in very VERY far and it will shift). I just had all these problems plus the cruise control issue and they were all linked to a POS Brake Lamp Switch.
Hmm interesting, I'm occassionally having the same issue with my car thinking it was Torque Lock. However, everytime I stop my car, I engage the parking brake and shift into park like you're supposed to, only for it not to shift out of park.
The brake lights at the rear would on and only when they shut off am I finally able to shift out of park.
Plus as you mentioned, the cruise control would sometimes cut out as I'm driving and would only turn back on once my vehicle comes to a complete stop.
My co-worker who was following behind me told me that while I was driving, my brake lights would continuously be on.
I have a 2006 Pontiac G6 GT, so would all this be a reult of the POS Brake lamp switch as well?
