1 - 9 of 9 Posts
Pontiac G6 GT Coupe
I've had my check engine light scanned twice with the same problem of the catalytic converters missing. I had them clear it and it came back. I'm not too sure how to check and if they are missing how can I go about preventing the light from being on? I've ran gumout through my fuel tank in the last week and it hasn't done anything for me yet. Not sure what the problem is, or how to solve it. Any advice PLEASE HELP!!!
Sorry to give you a non-answer but posting the actual codes along with the engine size might help others better understand the problem. When I read the phrase "catalytic converters missing" I am thinking there will be a big gap in the exhaust where the cat(s) used to be, and I doubt this will be the case as it would be easy to spot and the fix would be relatively obvious.
If the codes are for the catalytic converter being outside efficiency tolerance, I would think you have two main choices: -
  • Replace the failing catalytic converter (clearly the right thing to do)
  • Fool the emissions system by installing a spark plug non fouler on the secondary O2 sensor (may get you into trouble if discovered depending on local laws, environmentally inconsiderate, etc)
With the actual codes there might be other options / info.
Hope this helps
BOOMER: I think your 2nd fix is more likely to fix that problem. If the ECM knows that a sensor is missing or not registering some codes, it will give an error code. any sensors missing from the "LOOP" will cause a bad read to the ECM.
Pontiac G6 GT Coupe
Discussion Starter · #4 ·
Hope this helps
The code my engine is throwing is P0420. Catalyst system low efficiency.
Oxygen sensors in the exhaust don't last forever, recomended replace them at 100k miles. An older UPSTREAM O2 sensor that is failing will set this code. BTDT with a number of my own vehicles over ythe years.
Pontiac G6 GT Coupe
Discussion Starter · #8 ·
WELLLL.....NO cats and nowhere for the sensors to read from. NO fix without the system being correct.
Do you think having my exhaust guy put an o2 sensor would be able to fix my problem? The previous owner stripped the cat and just straight piped it i guess.
Pontiac G6 GT Coupe
Discussion Starter · #9 ·
Hope this helps
Code is P0420, would I be able to use your second tip and kinda fool the system? I could probably have my exhaust guy put an o2 sensor on my exhaust so it can read something.
1 - 9 of 9 Posts
