1 - 12 of 12 Posts
I have the 4 sliding windows idk how to call it.... panoramic or moonroof or wtever... the thing is that is stopd working... it wont open at all!!
does it run or does it try to open and doesn't. If it doesn't move at all then it is a fuse or maybe the motor, if it does open sun but not like it should then the frame assembly is broken and you need to get the whole assembly replaced. I had the same problem with mine dealer priced it at $1600 in parts and labor. Sorry to hear all of this hope that it's just a fuse or motor, it'll be a lot cheaper.
It tries to open but it doesn't man.... the plastic cover moves bak and forth but da roof won't.... how can I kno If its a fuse m which one
are there any sounds from it, you should be able to hear the motor trying to go if not then fuse idk which one right now I would have to go look for sure or its the motor. If you hear the motor or if the glass moves even a little bit then your track is probably broken.
Discussion Starter #9
yea it makes a sound like if it wants to open but doesn't and glass moves jus a lil
I would say the track is broken then, sorry it sucks having a gorgeous sunroof and not be able to use it. look at car-part.com to find one cheaper if you still want it replaced
Discussion Starter #12
Hopefully is jus dat.... ima search on the web and see wat i can find... i really miss da roof :( its perfect time to show it off here in south Tx. thnx for the help... thnx :)
1 - 12 of 12 Posts
