1 - 9 of 9 Posts
So I have run into a little issue. My Girlfriend has got a flat tire and it is not repairable. We located some used snow tires from a friend. They are 235/50/17. As you know the stock size is 225/50/17. Is it ok if the 2 back tires are a little bit larger for a short time? Will they even fit without issue? I know the speedo would be off a little bit but again this is a short time remedy till winter is over.
1 - 9 of 9 Posts
