anyone with a 08 gt coupe with the monsoon system replace the factory speakers? what did you use for a bracket for the speakers? And sorry if this is not in the right section
18758
2006 G6 GTP F40
If you get the right speakers, they should drop right in. Keep in mind, something very very important!!!! The monsoon system uses speakers rated at 2 ohms. If you get a 4 ohm speaker, you will loose sound quality and volume. I just did my 6x9s on the rear deck and learned the hard way.
The speakers I bought are rated for 2.7 ohm and i'm also using the factory amp
